Club323F • View topic - inttake pipe
It is currently Thu Oct 29, 2026 5:45 pm
kieranv6
 Post subject: inttake pipe
PostPosted: Mon Feb 11, 2008 8:02 pm
i am going to make one myself as i cant find one for my broken one.
but if i make one out of piping what do i do with the pipe that come of the standed pipe? and what is it aswell. its about inch wide round tube, it right next to the the metal to rubber conection.
Dazp1
PostPosted: Mon Feb 11, 2008 8:27 pm
It's for the valve cover vent pipes.
kieranv6
PostPosted: Mon Feb 11, 2008 8:40 pm
so what can i stick on end of it then?
griff88
PostPosted: Mon Feb 11, 2008 9:10 pm
if its the pipes that i think it is then you can but little filters that go on the end of them.
lok like little induction kits. cool as in my book.
griff
kieranv6
PostPosted: Mon Feb 11, 2008 11:32 pm
http://cgi.ebay.com/ebaymotors/NEW-12mm ... enameZWD2V these things?
PostPosted: Mon Feb 11, 2008 11:41 pm
post ford has one pipe coming off - can indeed just be replaced with a breather filter on the engine side
pre ford has2 pipes - the same as above + one other pipe which i have no idea what it does, where it goes or how to get around it
so hopefully you have the post for version :thumbright:
kieranv6
PostPosted: Mon Feb 11, 2008 11:57 pm
i only got 1 pipe i think. well i sure i have. so breather on there some alloy pipe from engine to air flow then filter. sounds good. my flat spot from my tear in the rubber doing my head in.
PostPosted: Tue Feb 12, 2008 8:54 am
The pre-ford's extra pipe goes to a small resonator box to help throttle response or something. Ford ditched it, though no-one seems to have noticed a difference. Maybe it's effects have been handled elsewhere - ECU maybe.
nat1979
PostPosted: Sat Mar 08, 2008 12:36 pm
so when you connect the breather filter to the pipe on the engine side what would i use to seal the hole on the intake pipe (post ford)?
kieranv6
PostPosted: Thu Mar 13, 2008 7:14 pm
right done mine i will take pic and show you what i done. i made it all myself in work
A L 3 X
PostPosted: Thu Mar 13, 2008 7:25 pm
[quote="Mark.T"]The pre-ford's extra pipe goes to a small resonator box to help throttle response or something. Ford ditched it, though no-one seems to have noticed a difference. Maybe it's effects have been handled elsewhere - ECU maybe.
Mark[/quote]
are u talkin about the reso box in the wheel arch which most people remove or a different one?
ph3n1x
PostPosted: Sat Mar 15, 2008 1:52 pm
mark t means the little box in between the intake piping, the carter vent pipe and the idle air intake.the first 2 make a T junction to the idle air. After Ford took over they ditched that and added a sort of Y connection in between and removing the mini box
