It is currently Sun Sep 13, 2026 12:05 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2
 Post subject: Re: I just can't fix it
PostPosted: Fri Aug 26, 2016 1:07 pm
am I completely missing something there?
spark plugs
MAF
TPS
not ignition/HT leads? :roll: :dontknow:
MadazInBris
PostPosted: Fri Aug 26, 2016 1:16 pm
10:14pm here as I type this...
Going to the naughty cnr Lerch & bury my head in a bucket of sand as I *mis-read* it !! :? :oops: ;) :lol:
PostPosted: Fri Aug 26, 2016 2:32 pm
Madazinbris, don't be so hard on yourself.. :lol: :lol:
Stop the chit-chat and help the guy.. ;)
MadazInBris
PostPosted: Fri Aug 26, 2016 3:02 pm
Well he could go & buy a TOYOTA I guess / ;)
PostPosted: Fri Aug 26, 2016 3:40 pm
Firstly Lerch's idea is a good one. Make sure the leads are OK. This requires testing- with your eyes, hands and a multimeter.
cojocariu.adr wrote:
I did spray cleaner in very small percentage on the MAF but after the problem. I checked the MAF, it looks ok ( not burnt off in any case ) and I dried it well before putting it back. Disconncting the MAF makes a big difference in engine revs and stuff, so I think it kinda works ok.
That's a good sign. Note you do need to use a MAF safe cleaner. Even if the solvent you sprayed has 'dried', if it has left a deposit on the MAF it will interfere with its operation. I'm not familiar enough with the car yet to say what type of MAF it is (and mine's not near me).
I did try the pulling fuel cap off, nothing changed. Disconnecting the O2 senzor aka Lambda Sonde didn't make any effect at all. I'm thinking maybe that's the problem ?
Thinking it is isn't good enough. Those things are expensive. You need to test. This will involve either time, or money, or both. You either need your own independent probe for the exhaust or someone else's. Furthermore if it does show an issue it may not be the problem- just something damaged by something else, e.g. lead in the fuel, or too much fuel in the exhaust, etc. O2 sensor is probably more important under heavy load/acceleration. Also errors from it may e a little while to show up on the ECU unless it's shorted or disconnected, and even then may take a minute or two.
As for coolant in oil, no, there's no coolant in oil. But the radiator has a small leak somwhere, not too bad yet, but it will be replaced as soon as i fix engine problem. I used some leak sealer in the coolant so it's a little reddish now.
Not sure how these engines take leak sealer, others will know better than me. They can cause issues (the sealers, not the others! :lol: ).
Pitrack_1 I don't get what you mean by "Locate the leak by squirting some ether or Aerostart around, there will be an increase in revs when you hit the right area. "
But I did blow cigar smoke in it and I can't see it anywhere...
Aerostart is a trade same for an ether-based substance in a can that you squirt into the air intake to assist with starting recalcitrant motors. Also known as "Start ya b*****d" in Oz. If you are unsure you can google it. Another hydrocarbon source from a can should do.
I am unfamiliar with cigar smoke being able to assist with starting engines or being known as an analogue for Aerostart!
Taking off the oil cap doesn't fume too much, but there is a very small line of steam like fume. It kinda takes 3-6 months driving for it to take from Max oil to Min but I don't drive much. And if I park it I can see small oil circles on the ground, I can't really knew where it comes from because it leaks on the car under cover first, then it leaks on the ground. The oil stains are usually as big as an keyboard big ENTER button.
The oil fume level sounds good, no problems there. That oil usage sounds normal, maybe slightly more than usual, you should be fine. You should not use more than 1l/1000km. You also have a small leak from somewhere to be investigated.
Another test with the dizzy- mark first then try rotating it (loosen but not too much) whilst holding the engine at ~2000-2500rpm. Hold the throttle constant and rotate the dizzy, you should hear and notice an engine note and revs change. Find where the revs are highest and it sounds the best, then back off (rotate dizzy in direction of engine/dizzy rotation) a few degrees.
A cracked rubber intake pipe (usually underneath, where you can't see it) is not uncommon.
Sorry I can't be more helpful than these general suggestions.
MadazInBris
PostPosted: Fri Aug 26, 2016 3:58 pm
Dizzy is Aussie slang short for distributor (Pat should know better by now lol) :lol:
cojocariu.adr
PostPosted: Sun Aug 28, 2016 4:40 pm
Ok. Lerch is right, I haven't changed the Leads. But I did check them by eye and they pass current with a multimeter, plus, unpluging a lead with the engine running and approaching a mass will give regular sparks to the mass, so I can see the current gets to the spark plugs.
I'm missing the rubber insulation on 3-4 spark leads I think ... I'm going to consider replacing them, but...
Lerch wrote:
I've had a quick skim through this but have you changed the ignition leads? I've had this issue a few times and it was a lack of spark as the leads were goosed!
Do you mean this problem ? Like mine ? Please take a quick look at the video.
https://youtu.be/NwH3rm2qD7E
"Car idles fine, and if I slowly accelerate all good, it seems to pull, but when I floor it... it chokes and misfires."
This is how the lamba sonde (O2 sensor) looks. It used to be covered in oil before, when the leaking was worse, but "mechanics" "solved" it... so it seems.
Car still leaks a little I think it's through the oil filter, probably badly placed... who knows... maybe pressure from the engine blasts forces oil out ? If the piston seals aren't good ? That sounds like terminal engine problem though... I hope not...
Here's a pick of leak ( 2 weeks unmoved car ) and dirty/oily oil filter, all over.
And from beneath:
Also, pitrack, this is the PCV ?
When I took it to mechanic a while ago when he change filters and "fixed" the oil leak, he broke this... he said the rubber was old and just disintegrated but I don't believe him because I know I pulled it and it looked solid ! This is an improv he made...
I'll buy a new one though.
This one sucks really good ... but there is a lot of dirt in the hole.
Watch video too see the vacuum.
https://www.youtube.com/watch?v=dn5ru0w ... e=youtu.be
PS, this youtube video file name ends in 323 xD It's how the phone recorded it !
Also, you can hear difference of engine rev when I unplug it... Sooooo I guess that pretty much means the vacuum is strong, and that there are no leaks !
And... for all... idling is just fine. Problems kick only when I floor it.
turbo5513
PostPosted: Sun Aug 28, 2016 10:13 pm
The same thing happened to me on the 1.5, it was a vacuum leak combined with dirty injectors and a clogged fuel filter! The vacuum box had a massive crack along the middle. Also the intake hose where it is ribbed was cracked. Its fairly common.
cojocariu.adr
PostPosted: Fri Sep 02, 2016 11:59 am
turbo5513 wrote:
turbo5513
I kinda doubt it's the injectors though. Could be vacuum leak but so bad ? I mean... I've played with my car unplugging hoses and it didn't do these kind of things... The idle revs would change a very tiny little but that's about it. I will search better for leaks though.
cojocariu.adr
PostPosted: Thu Sep 15, 2016 11:16 pm
After changing the distributor rotor arm and cap, as well as the ignition leads, no effect !
Car still sputters at WOT (wide open throttle).
With the car key at ON and engine off, I can read no error codes with my led diag. But with the engine started, I kinda read code 18. It's not listed anywhere, and it might be 1 and 8 or 10 and 8, but from what I know, 1 and 8 will mean car won't start.
I've looked at the MAF (code 8) and it's not burned out. Unplugging it with the car on changes revs and makes idle worse.
And from what I know, diag is made with engine off...
It might be TPS, I will check it it's voltage to see if it's working next week when I return to work to the car.
I hope it's not one of the hard to reach sensors as camshaft or crankshaft sensors.
Also, next week I'm planning to do the external ignition coil mod. I hope I can do it without modifying the distributor. I have a spare dizzy cap now so I'd rather cut out that one.
I'm reviving the thread, because MSD parts are hard to get here, I want to see if the ones there are good.
If you've done the mod, please answer me on the thread here:
viewtopic.php?f=19&t=46035&p=751059#p751059
Thanks !
PostPosted: Fri Sep 16, 2016 7:48 am
I've just caught up with this. You say you've visually checked the HT leads for spark and conidition etc - I did the same on my old 1.5 and everything seemed fine....however, when i bought a new set and fitted them it felt like a completely different car. Is there any way you can get hold of another set, maybe from a friend, and just swap them over quickly to try it?
Looking forward to see how you get on with the external coil mod! :thumbright:
PostPosted: Fri Sep 16, 2016 10:24 am
Maybe it was asked before but, did you changed the fuel filter?
It could be bad fuel also..
cojocariu.adr
PostPosted: Fri Sep 16, 2016 11:37 pm
The HT leads I bought are definitely good. The same problem occurs as with the old ones. The problem is a little too severe to be HT leads.
maZZda I changed the fuel filter 4 months ago, 1 month prior to the proble.. I think it s good but after the ignition coil mod.if it doesn t work I ll change it maybe something came and got it stuck.
If anyone can answer me on the ignition mod thread I d be grateful.
Thx guys.
