It is currently Sat Oct 03, 2026 9:06 pm
mmpob
PostPosted: Mon Aug 08, 2005 4:11 pm
remove the screw from the door pocket/grip
One more screw hidden in the door handle
Finally, remove the clip holding the door winder in place, again with a flat head screwdriver. You will need to push the door card in a bit to get at the clip. Watch out, the clip will try to reach orbit! Best bet is to have someone else with their hands cupped nearby, otherwise, try and aim it into the car. Mine landed in the driver seat after a few rebounds!
Now to remove all the poppers holding the door card on. I found it easiest to go around the bottom with a screwdriver, leavering the card out. See the photo below for all the poppers. Leave the ones in blue until last, you will need to lift the door card up to get them out.
A popper
If you need to take off the plastic sheet to get at the door lock mechanisms, put some rubber gloves on! The black putty/glue/gunk is a b*tch to get off your hands, arms, clothes, shoes, car....
Now to put it back together again, just follow the reverse!
m0053
PostPosted: Mon Aug 08, 2005 4:32 pm
last time i did this, the metal supports that hold the poppers detached from the door card. if this happens to you, normal quick-drying superglue is adequate to bond them back to the doorcard, however, the metal supports are shaped to fit each placement so dont get them mixed up.
nice guide :faroah:
PostPosted: Mon Aug 08, 2005 5:05 pm
Yup, mine do that everytime i take the cards of, so far, no glue has worked :( gonna try Evo-Stick Wet Grab next :D:D
Just one thing, mmpob, why do you remove the 'small plug thing' isn't that part of the door seal?????
Great guide :D:D
mmpob
PostPosted: Mon Aug 08, 2005 5:16 pm
heh - i have no idea!!!
if it looked removeable, it came out ;)
JDM
PostPosted: Mon Aug 08, 2005 5:53 pm
:cheers: excellent guide mate, very helpfull as i will be taking mine off very soon
JDM
PostPosted: Tue Aug 09, 2005 6:54 pm
ok well ive just done mine! mine is an electric window so i guess i got few more wires that need uplugging than non electrics but hey. this guide is very good indeed, it help alot. i managed to take mine off with ease, just need bruteforce when all the screws are off. kinda run your hands from one side to the other making sure all the poppers are out then just remove the card. i was abit confused with the white block where the speaker wired are connected to as the connection block wouldnt fit my new speakers :scratch:
oh and trust me like the guide says... AVOID the black stuff that sticks like hell :laughing8:
ShaMana
PostPosted: Tue Jun 23, 2009 7:49 am
Hello, all.
Is there any chance to renew this guide with the photos. Really need the visual instructions to do it. :)
Mase
PostPosted: Wed Jun 24, 2009 1:50 am
Where are you from, if you are local to someone they can do it for you.
It is real simple. Try following the instructions without the images.
Record holder for the highest mileage from a 1.8i Exec BA - 428.9miles :razz: :D:D:D
gretski
PostPosted: Thu Sep 15, 2011 12:34 am
reposting of pics would be awesome :D
CSR
PostPosted: Thu Nov 03, 2016 6:23 pm
can pots pictures again? I cant remove the back doors cards... only the front... :D
by the way, my are post ford (eletrical windows). Is much diferent? Probably onlya have to disconect the plug wires right? :roll:
