It is currently Thu Aug 27, 2026 5:52 am
bubble123
PostPosted: Mon Sep 27, 2010 6:50 pm
Does anyone know how to alter the angle of the headlights - actually within the light fitting itself. My lights are way too low to the point where it's dangerous to drive at night because I can't see the road. The control inside the car for altering the headlights is on maximum but the lights are still pointing too low. Help?
PostPosted: Mon Sep 27, 2010 6:54 pm
firstly, make sure your bulbs are correctly fitted into the lamps - if they are slightly out, the beam will be way off.
Then look for the screw adjuster on the headlight itself - a big philips I think, and turn it - you'll see the light coming up as you turn (or down, if you're turning the wrong way)
PostPosted: Mon Sep 27, 2010 7:08 pm
Correct - first thing is to make sure the bulb is fitted correctly and that it is the correct bulb (a H1 bulb will "fit" into a H3 socket, but it won't be straight), then switch the lights on. Do this in the evening so you can see the lights on the road. There's a screw right at the wing side of the headlamp, sticking up about 2 inches from the light itself. Turn that with a screwdriver (philips). If the light raises, good. If it lowers (or wont turn), turn it the other way :thumbleft:
steven
PostPosted: Mon Sep 27, 2010 7:41 pm
My Car: 1998 Imola
what they said :lol:
and a wee guide for your perusal too
http://www.club323f.com/?page_id=931
11r Cars are the fastest
bubble123
PostPosted: Mon Sep 27, 2010 8:14 pm
Thanks for your help - much appreciated :)
bacz
 Post subject: Re:
PostPosted: Thu Dec 02, 2010 4:17 am
link does not work now :(
steven
PostPosted: Thu Dec 02, 2010 9:54 am
My Car: 1998 Imola
The guides are not available until the update has been sorted. It will be up soon enough mate!
PostPosted: Mon Dec 06, 2010 11:27 pm
Personally I would take it to any good MOT test station and ask them to check it for you, Most will oblige and probably charge you £5 for it :dontknow:
The only downside of doing it yourself is you never know when it's too high for oncoming motorists, Something which is a pet hate of mine :thumbup:
BillyBoy
PostPosted: Tue Dec 07, 2010 11:50 pm
Like _stuz_ said. First check the bulbs are seated correctly then go to a MOT station and have them adjusted properly. Mine needed adjusting for the MOT and it made a world of difference. I drove the car for nearly a year thinking the headlights were crap. I fiddled around with the adjusters trying to improve things but couldn't. When they were adjusted properly they were brilliant and I can now drive down unlit B roads without using main beam they're that good. Well worth spending the few quid.
Users browsing this forum: Bing [Bot] and 2 guests
