It is currently Sun Oct 11, 2026 8:11 am
hafizkam
PostPosted: Mon Aug 10, 2009 5:53 pm
hey.
today i have purchased the rear electric window regulators off parvez.
he told me they were out the v6.
can anyone please confirm that they will fit i my 1998 S reg 1.5 lxi BA model?
and is it plug and play? or will ihave to change looms and stuf?
thanks
parvez
PostPosted: Mon Aug 10, 2009 5:56 pm
Will fit fine. I've sold you everything you'll need, plus more :D
Have a look at the following threads which should help:
http://www.club323f.com/club323f/forum/ ... php?t=5366
http://www.club323f.com/club323f/forum/ ... hp?t=31329
jasonwoolcott
PostPosted: Mon Aug 10, 2009 6:20 pm
ha not like he ripped you off or everything, im sure its everything and you wont need anything else, just take your time and you will be fine!
keifling
PostPosted: Mon Aug 10, 2009 7:18 pm
i will list the steps for you so as to avoid the same frustrations i met with!
1. replace the driver wire loom from the driver side dash to the driver door.
this involves unpluging everything from the driver door and replacing with the new loom just to have the different window switch plug.
2. the above will mean you need the portion of the door card with the hole for the 4 door switch along with the switch itself
3. once you have done 1&2 you should have the same functionality as before....plus two extra buttons that do nothing and will eventually operate the rear windows.
4. in the rear doors replace the loom from the car to the door, extra plug for the motor but take note as central locking and motor wire have same size plug. make sure no wires will hit the mechanism, your gonna get sticky hands.
5. remove glass by undoing the 2 stops at top, the 3 nuts/bolts on the middle runner attached to glass
6. remove the middle rail and manual winder
6a. take the bolt from the middle rail that has an allen key slot. this needs to go in your new leccy rail and it used to adjust the angle. it needs to go in with about 1.5 cm between middle round part and frame for the window to shut right.
7. fit new motor and rail.
8. fit glass into the rail
9. fit stoppers at original position (in paint) so window seal correctly.
10. do the other side
hafizkam
PostPosted: Mon Aug 10, 2009 8:44 pm
very Helpful Keifling
many thanks
kam
PostPosted: Mon Aug 10, 2009 8:46 pm
and test it all before putting the cards back on etc :thumbright:
keifling
PostPosted: Mon Aug 10, 2009 8:54 pm
give me a pm if u get stuck
once u have done one side the other is easy
hafizkam
PostPosted: Mon Aug 17, 2009 5:24 pm
i have put the new drivers loom in.
now the rear doors i dont understand. i have connected the socket from the motors to the ones in the door but for some reason dont work.
any ideas?
thanks
hafizkam
PostPosted: Mon Aug 17, 2009 5:26 pm
as above when keifling says: 4. in the rear doors replace the loom from the car to the door, extra plug for the motor but take note as central locking and motor wire have same size plug.
i dont understand.. i do not have a loom for it.?
help.. lol
hafizkam
PostPosted: Mon Aug 17, 2009 6:23 pm
this is the rear door with the door card off..:
and this is the rear motor and rails i have been given:
and switches:
where do all these go. lol
keifling
 Post subject: hmmm
PostPosted: Mon Aug 17, 2009 6:35 pm
u def need a different loom for the rear
has the extra wire for motor power and another for the switch (which is cut off on yours)
x2
PostPosted: Mon Aug 17, 2009 7:14 pm
speak to dazp1 on here - see if you can get his rear looms off of him
hafizkam
PostPosted: Mon Aug 17, 2009 7:39 pm
i bought everything off parvez so he said he going to have a look... thanks guys
keifling
PostPosted: Sun Aug 23, 2009 7:53 am
i edited my instructions above, its more or less a mini retro-fit guide now.
keifling
PostPosted: Wed Aug 26, 2009 9:37 pm
here is a pic of the middle rail and holder that needs 3 bolts unscrewed to get the glass out. in this case the glass is out of the metal holder (top of pic)
it also clearly shows the angle adjuster bolt
here is a pic of one of the two blocks that need to be removed
hafizkam
PostPosted: Sat Aug 29, 2009 1:56 pm
cheers mate. i will be having a go next week some time as started work again now. thanks for your help
keifling
PostPosted: Sun Aug 30, 2009 10:39 am
good luck!
