Club323F • View topic - engine flush
It is currently Sat Nov 14, 2026 4:59 pm
will
 Post subject: engine flush
PostPosted: Mon Dec 12, 2005 11:18 am
morning all
i want to do an oil change next weekend and want to do an engine flush as well to see if i can stop these noisy hla's on start up.
have done the oil change before no problem but never done a flush. have seen lots of topics etc about this but cant find them.
what are peoples opinions on the various products out there? and what should or shouldnt i do/ use?
thanks for any advice
Will
ps its a v6 if that makes any difference!
PostPosted: Mon Dec 12, 2005 4:05 pm
I've used engine flush fluid in the past and it does help. All you do is pop the bottle into the engine and run it for 15-20 minutes, occasionally reving it, after that you just do the oil change as normal.
Although I beleive the correct way you flush an engine is by emptying the oil then filling up with new, running for 30 minutes, then draining the oil and re-filling with some more new oil.
will
PostPosted: Mon Dec 12, 2005 9:11 pm
mike
what fluid did you use? any brand better then the rest or do they all do the same thing?
Will
Users browsing this forum: Google [Bot] and 12 guests
