It is currently Sun Sep 13, 2026 11:18 am
_WoLFMaN_
PostPosted: Sat Apr 27, 2019 5:47 pm
There's a pipe sticking out of the radiator. Is that for draining air?
PostPosted: Sat Apr 27, 2019 6:43 pm
If you mean at the top then there should be a pipe from the radiator neck to the coolant reservoir.
_WoLFMaN_
PostPosted: Sun Apr 28, 2019 8:57 pm
I'm pretty far away from my car but it's a pipe with a blue cap that says H on top of it, and if I take off the cap it has a valve, just like the ones from the wheels.
PostPosted: Sun Apr 28, 2019 9:15 pm
Man, that's a valve for the aircon high-pressure line.
Don't touch it!
PostPosted: Mon Apr 29, 2019 3:35 pm
Don't touch it!
As maZZda says, it'll drain something, quite quickly, and it's not air!
Also it should not be going to the radiator but to the condenser for the A/C- which looks like a radiator (which it is, but for the A/C refrigerant), is possibly silver-coloured and is mounted in front of the engine coolant radiator, which is likely coloured black.
You may also find another valve cap on another pipe, likely with a "L". That's also the A/C, low-pressure side- don't play with that either!
