Club323F • View topic - Wheelspin .....
It is currently Sun Nov 15, 2026 12:14 pm
 Post subject: Wheelspin .....
PostPosted: Thu Oct 27, 2005 4:05 pm
Ok heres a question for you tecnical boys - or rough ass wheelspinners lol
When you set off wheel spinning whats it mean if the wheels "Jump" ?? What I mean is If you hear a clunk when wheel spinning could this be the driveshafts are on their way out ?
Any help appreciated as per normal ./....
DanG
 Post subject: Re: Wheelspin .....
PostPosted: Thu Oct 27, 2005 4:33 pm
[quote="GOGOBROOM"]Ok heres a question for you tecnical boys - or rough ass wheelspinners lol
Any help appreciated as per normal ./....[/quote]
u boi racer you!
stuartspel
PostPosted: Thu Oct 27, 2005 6:19 pm
Dan, I reckon - Its more likely to be one of the wheels spinning then gripping momentarily giving you the feeling of it jumping. When a driveshaft goes……..It goes.
As a tester – try it on a wet surface, bet there’s no jump or clunk feeling then.
PostPosted: Thu Oct 27, 2005 6:27 pm
Am not known as a bot racer ... that is unless I am on the "strip" and this is where it is happening - just before you go to the start line, where it is all whet and where you are supposed to spin... this is where I get the clunk :S
PostPosted: Fri Oct 28, 2005 12:23 am
Could be that they're just jumpin, i've had it before, apparently its more common when you increase the wheel size for some reason????
Toyboy
PostPosted: Fri Oct 28, 2005 1:52 am
Also you'll find that it will jump more when both wheels are trying to spin...
RedAstina
PostPosted: Tue Nov 01, 2005 2:34 pm
its called wheelhop or axle tramp...it happens when the wheel suddenly grips and then stops grippping. The give is in the engine mounts and driveshafts so the wheels hop. Changing to stiffer engine mounts or filling the standard ones helps alot.
