It is currently Sat Sep 12, 2026 11:04 am
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2  Next
A L 3 X
PostPosted: Sun Feb 06, 2011 11:48 pm
I've searched for almost an hour now, read every topic I could find from top to bottom but the actuall guide seems to have disappeared...
Basically as I have gathered from other threads are you meant to get the engine warm then use a piece of wire to join the TEN and GND pins in the diagnostics port, then adjust the idle screw so it idles around 850....and when removing the wire they should drop to 750?
Also I only have a Sealey tools multimeter which I don't think has an option for RPM, is there a way to do it on a voltage setting or something or can you just adjust the screw then run around and check on the dials in the car?
PostPosted: Mon Feb 07, 2011 2:46 am
Just use the dials :lol:
Bridge the pins in the port, adjust the screw, look at dials, adjust screw some more, look at dials, repeat until desired RPM, remove bridge. Takes maybe 3 minutes if you're slow :lol:
A L 3 X
PostPosted: Mon Feb 07, 2011 2:16 pm
oh lol sounds easy, i thought you had to use a multimeter, and mine doesnt seem to have an rpm function, is the right rpm 750? Cos some threads said 750 others said 850 but when you remove the wires it will reset to 750?
PostPosted: Mon Feb 07, 2011 2:27 pm
Nope just a bit of wire between ten and gnd will do the trick, then use the dials in the car to check the revs. I do about 850rpm, it drops when you disconnect the wire :)
A L 3 X
PostPosted: Mon Feb 07, 2011 2:43 pm
ah brill mate, cheers
A L 3 X
PostPosted: Mon Feb 07, 2011 6:28 pm
Had a go today, seems to be better now, although even when I turned the screw all the way so it wouldn't go any further...the idle still sits a little above the 750 mark...how come?
It is better than it was yesterday after fitting my ported and polished TB. :)
PostPosted: Mon Feb 07, 2011 6:58 pm
You might have ported too far into the throttle body...if you've gotten too close to the butterfly, it will allow too much air in at idle, and do exactly what you're saying :roll:
A L 3 X
PostPosted: Tue Feb 08, 2011 12:18 am
Oh no mate I didn't go anywhere near that bit as I read RY4N's guide, i only cleaned the old gunk form around the butterfly and further in from it, and then just polished around the butterfly....the bits at the entrance to the TB way before the butterfly were the bits i grinded down till smooth then sanded and polished....although it does seem to be about perfect now, the needle just rests on the top of the 750 mark which I read is good to be slightly over rather than under....yet the screw is still fully closed? Its like you turn it a little bit and it goes from 1.1k to 1k....and the same for 1k to 900, then you have to turn it for ages until the end before it touches 750......weird :?
PostPosted: Tue Feb 08, 2011 12:20 am
hmmm ive never reached either end of the scale but as long as it idles ok, and when you're pulling up it doesnt drop down to 400 or scream up to 1200 it will be fine :) when braking, mine stays at about 850 till i stop, then it drops to 750 which is fine for me :)
marc_frobie
PostPosted: Tue Feb 08, 2011 12:22 am
mine sometimes drops to about 400.... do i need 2 re-set it by doing the above? or could i make it worse? :p 8)
PostPosted: Tue Feb 08, 2011 12:26 am
Yeah I would adjust it :) Open the diagnostic port, bridge pins TEN and GND while the engine is running at normal temperature. The revs should drop - turn the screw on the throttle body until the revs are back up at about 800-850rpm, remove the wire from the port, job done :) takes literally seconds. I might make a video guide at some point
marc_frobie
PostPosted: Tue Feb 08, 2011 12:27 am
ok might give it a go - are the pins marked? Cheers bud :thumbright:
A L 3 X
PostPosted: Tue Feb 08, 2011 12:29 am
Thats what I find really weird, makes me wonder if I have cocked something up somewhere? Can't imagine perfect idle being right at the end or there would surely be no adjustment :?
Ah yeah mine stays just under 1k when braking if you put the clutch in but when you stop it drops down, weird
You might have a diagram on the inside of the lid - neither of my BAs did, but every other one I've ever seen has :lol:
In case you don't, you can't go wrong with these:
EDIT: Mine is near the fully open mark alex, I did hit it while turning, then turned it back a bit - didn't give it a chance to look at the revs :lol: and yeah thats down the vacuum in the brake lines :) When you stop, I believe the ABS pump kicks in to relieve brake pressure (could well be wrong here) which reduces the vacuum and lets the revs settle.
marc_frobie
PostPosted: Tue Feb 08, 2011 12:31 am
haha cheers 4 that! 8)
PostPosted: Tue Feb 08, 2011 12:32 am
Ignore the comment on the fuse :lol: it will be fine. I have a paperclip stored in my enginebay for fine adjustments :lol:
A L 3 X
PostPosted: Tue Feb 08, 2011 12:50 am
Ah so yours is near fully open and I prosume mine is near fully closed...It is fully turned to the right? Very strange but if it works it works, might try the lambda sensor refurbing guide if I can work out how to loosen the lambda sensor :lol:
Oh and tomorrows job is trying to fix my ignition barrel :( This car used to never seem to develop any faults, now they appear to be starting constantly...I did tell it I was gonna sell or break it for parts though earlier so lets hope it listened and starts to behave :lol:
Sloth
PostPosted: Tue Feb 08, 2011 1:08 am
Think I might give this a go too, mine drops down to 400 quite a lot when braking/putting the clutch in as well.
eogbaker wrote:
http://blog.sloth.org.uk
Rob
PostPosted: Tue Feb 08, 2011 1:32 am
Good luck on the lambda sensor Alex. Mine was an absolute bugger to get out. In the end I had the front end jacked up, a blowtorch to heat up the downpipe, then a big stilson pipe wrench from underneath with my foot on it pushing for all I was worth!
Once I got it out, the trick of heating the element with a blowtorch worked a treat, sorted out my erratic idel perfectly.
Rob
A L 3 X
PostPosted: Tue Feb 08, 2011 1:39 am
Cheers Rob, need to think of something to get it shifted....may sound silly but whats a stilson pipe wrench?
I don't seem to have any idle problems but I read that guide and at the moment I'm just trying to give as much of the engine as possible a quick bit of maintenence to try and release any lost power and economy, not sure if it will work but the porting and polishing of the TB has deffo made the rev range smoother and seems to have improved throttle response. :thumbright:
PostPosted: Tue Feb 08, 2011 7:00 am
sma with my lambda - downpipe heated to get it out
PostPosted: Tue Feb 08, 2011 9:08 am
Mine came straight out with an 18" wrench :roll:
marc_frobie
PostPosted: Mon Mar 14, 2011 3:32 pm
Just done this guys, 1st time i bridged them the engine cut out, so i turned the screw anti-clockwise a few turns then tried again & it worked... dropped it back down to around 800 then took the pin out & it seems fine so far...
Question is, is this a perminant fix or will it start to drop again? If so how long does it seem to last?
(P.s this is dead easy to do & its worth a try doesnt even take 5 mins!)
PostPosted: Mon Mar 14, 2011 4:02 pm
Yep that's exactly how I'd do it :thumbleft:
Should be permanent, but if it happens again, just adjust again :lol:
silver_fish
PostPosted: Fri Oct 07, 2011 10:27 am
I've tried this after my engine was idleing @ 900 rpm.
i bridged the ten and gnd revs dropped to abot 5-600 revs adjusted them, un-did the ten/gnd bridge it's back ideling at about 900 revs. :?
came to work this morning and noticed a burning smell when the engines warmed up and the heater is on.. :( :shock: :(
What have i done wrong ?
Please HELLLLLLLLP meeeeeeeee.
PostPosted: Fri Oct 07, 2011 10:29 am
What sort of burning smell? Burning oil? Burning coolant? Burning plastic? Burning flesh? Burning toast?
How's your coolant level? Hows the temperature gauge? Does everything appear normal? Does the car drive as it should?
silver_fish
PostPosted: Fri Oct 07, 2011 10:34 am
Hughi,e Not sure mate, its a bit like leccky wire/heater burning.
Before i did the rev set, I swapped the o2 sensor and reset the ecu by disconecting the battey for 5mins and put my foot on the brake for a couple omins before reconecting the battery again
Was that the right procedure ?
PostPosted: Fri Oct 07, 2011 10:37 am
Has your heater only just been switched on for the first time in a few weeks? Most cars I've owned have smelt of burning the first time I used the heater in a while - dust on the heating element I always put it down to :lol:
That sounds right for me, although I've never bothered resetting the ECU with anything I've done to the car :lol: maybe take it for a spirited drive, see if the idle helps itself? The new O2 sensor is probably what's throwing the idle off, but the ECU reset should have sorted that I'd have thought :scratch:
silver_fish
PostPosted: Fri Oct 07, 2011 1:13 pm
Yes matey not had the heater on for a while.
Did the idle reset because it was idleing @ 900-950 rev's.
Changed the o2 sensor because when it was mot'd he said the emissions were up and down.
Also seamed to be using a lot of petrol of late.
When I changed it I put some copper grease on the thread.Could this be the grease burning off. :roll: :scratch:
Thanks for the help buddy. :thumbright:
kyrnikos
PostPosted: Sun Apr 01, 2012 11:40 am
i just finished with the ajdustment of the idle.i followed all instructions given above and everything went fine.it was very simple and took me less than 2 minutes.now the idle is much better than before but not perfect.a little trembling remains.so now i guess i have to clean the MAF sensor.
thanks a lot for the instructions guys.if anyone has something deferent to suggest please do so.
Users browsing this forum: No registered users and 56 guests
