It is currently Thu Aug 27, 2026 5:45 am
mmpob
PostPosted: Tue Dec 28, 2010 9:28 am
Whilst the first of the snow kicked in, I went over a painted roundabout, thinking it would be safer; unfortunately it just sent me sliding towards the kerb in which the front passenger wheel bounced off. As you can imagine this knocked the wheel alignment out quite a bit.
So I headed up to the local garage, they tried to realign the front wheels, but it seemed they were having trouble. They then said they would use their super laser thing which aligns front and rear wheels, and everything was OK. I also got a new set of front tyres as the old were barely legal.
Ever since, there's been a strange resonating noise that seems loudest around 43mph. There's no vibration in the steering wheel, and the car drives, brakes and accelerates in a straight line. It's a low pitched throbbing resonance. I thought maybe it was some frozen snow on the tyre throwing the wheel balance off, but now the snow has cleared, it's still there.
Any ideas?
DMS
PostPosted: Tue Dec 28, 2010 10:02 am
Sounds like the wheel is untrue.
PostPosted: Tue Dec 28, 2010 10:47 am
Possibly wheel bearing.
AlanK
PostPosted: Tue Dec 28, 2010 12:01 pm
sounds like a wheel bearing to me
mmpob
PostPosted: Tue Dec 28, 2010 12:29 pm
cheers guys, I'll get someone to take a look at it
lewp91
PostPosted: Wed Dec 29, 2010 1:45 am
i would vote bearing too..
PostPosted: Wed Dec 29, 2010 5:01 pm
I'd say you have a noisy tyre...as since you had them changed, you've suffered the noise...
swap wheels over (fronts to rears) and see if the noise stays with the wheel ;)
PostPosted: Thu Dec 30, 2010 3:07 am
I'd say bearing, as I hit a rear wheel into a kerb and bent the lateral link arms, replaced the rear axle, now i get a wobbly humming noise from the bearing (the only part left on the car that took some of the impact).
But Marc has a good point - try swapping the front/rear tyres over, see if the noise moves to the rear. If it does, it's the wheel ;) easier to replace than a front bearing
mmpob
PostPosted: Wed Jan 05, 2011 11:52 pm
cheers again guys - I'll give the swap over a go once I get the time :)
