It is currently Tue Aug 11, 2026 3:39 am
silver323f
 Post subject: interior light
PostPosted: Tue Sep 04, 2007 7:08 pm
does anyone know the length of the interior light for the ba's? im looking at getting a new led light but not sure what size, to me it looks about 30mm but the shortest i can find it 36mm?
http://cgi.ebay.co.uk/Rainbow-LED-Inter ... dZViewItem
PostPosted: Tue Sep 04, 2007 7:29 pm
Its 31mm chap, try www.ultraleds.com :thumbright:
silver323f
PostPosted: Tue Sep 04, 2007 8:57 pm
maybe im being a wally but i cant find it on here... :(
parvez
PostPosted: Tue Sep 04, 2007 9:00 pm
Which interior light are you referring to? :scratch:
PostPosted: Tue Sep 04, 2007 9:02 pm
Can't post a link to it, but, here's the details ;)
U31W1 (269) 31- 35mm Ultra Bright 1W Xenon White Dome Festoon Po £4.11
Ultra Bright 1W Power Led Dome Interior Light replacement
12 - 28 Volts DC
31 - 35 mm Xenon White Led Version
The Brightest 269 Bulb Available
Just replace the standard white Dome / Festoon / Interior Light with this bright White Led replacement.
High Power Ultrabright Wide Angle Led
Low Power consumption 40ma
Polarity Sensitive if this bulb fails to work reverse the polarity ( turn it the other way round)
Please measure the size of Bulb you require.
Easy Installation - Remove the old dome bulb and replace with this one - Simple and very effective.
Safe Voltage range 12 - 28 Volts
silver323f
PostPosted: Tue Sep 04, 2007 9:04 pm
do you know if they do a colour change one or is that only available in larger sizes? thanks for the help
silver323f
PostPosted: Tue Sep 04, 2007 9:14 pm
oh, sorry parvez, im reffering to the rear main light, but i would also like to change the map reading lights as well. prefferably coloured, dont want colour changing so ignore what i last said
Murray
PostPosted: Tue Sep 04, 2007 9:17 pm
yea you can get like red, blue, green whatever lol
maplights take 501 bulbs and can be found on ultraleds also :thumbright:
flathead screw driver into the small slot and lever the covers off, plug and play with the bulbs
PostPosted: Tue Sep 04, 2007 9:25 pm
Only in white on ultraleds chap, but I'm sure there are other places you can get colored ones :D
Murray
PostPosted: Tue Sep 04, 2007 9:27 pm
when did they stop doing them? i got my blue festoon one from them :scratch:
silver323f
PostPosted: Tue Sep 04, 2007 9:48 pm
thats a shame, was planning on doing a full interior light system. ill have a gander at some others. cheers
silver323f
PostPosted: Tue Sep 04, 2007 9:56 pm
just got a blue one off ebay for 3.95 delivered. wahay
PostPosted: Tue Mar 14, 2017 12:46 am
Update history
  • 14-Apr-2017 Confirmed
    • Glovebox lamp
    • Door (courtesy) lamps now listed as type 158
    • reformat listings
  • 12-Apr-2017 Confirmed
    • Boot lamp
    • Interior map lamps
    • Interior Dome (with map lamps) lamp
    • Post text
(Dredging up an old thread...)
Confirming my interior light specs for a 1994 BA hatch. I might this a small separate post, might be useful to 'sticky'. I've left out the filament design 'cos I think that' just going too far and LEDs won't obey it anyway. But I'm sure you know that already :)
Note these are for the hatch model- sedan boot may be different.
I'll colour what I'm after in bold red italics.
Confirmation required in bold orange.
Confirmed I'll make bold green.
And I'll try to keep an update date so people know where it's up to.
The ones I've confirmed are:
Hatch boot lamp:
Festoon T43x10.5/12866 (~41-43mm long x 10.5mm wide)
12V/10W
Door ("courtesy") lamps:
T3 1/4 wedge type 158 (roughly W5W size), 22mm long x 9.5mm wide, approx 6mm contact spacing
12V/3.4W
Glovebox lamp:
12V/3.4W
Interior Dome Map lamps:
501/W5W and/or T10 size, W2.1 x 9.5d
12V/5W.
This should be a fairly standard one, esp. for Mazda/Japanese.
Interior Dome (with Map lamps) main lamp:
31mm festoon x 10mm (9.5?) dia
12V/10W .
If anyone wants to add any extra info e.g. for dash bulbs, centre console bulbs, ignition key bulb (is there one? I can't remember) etc let me know and I'll pop them in here too. Be nice to have a canonical list.
Some useful sites for finding light bulb specs (apart from Google ;-) )are:
I'm not likely to dismantle my dash/console so I'll probably leave those bulbs out. Unless someone who already has them apart gets the info for me? (hint-hint! :) )
Be careful when you go to replace the bulbs- my plastics are all fragile now and when removing the door courtesy lamp cover (carefully too) the cover's tiny tab actually chipped off the holding plastic on the door fitting.
Cheers,
PostPosted: Wed Apr 12, 2017 6:27 am
It started raining when I wanted to drive the BA (can't get 'My Precious' wet now, can I? ;-) ) so I decided to do something useful.
Post subject: Interior Light Bulb Specifications- BA above has been updated. Hope it helps!
Cheers,
PostPosted: Fri Apr 14, 2017 3:47 pm
Found a glovebox light I didn't know I had 'cos it's never worked (dud contact)... well it does now and the spec has been added.
Post subject: Interior Light Bulb Specifications- BA above has been updated again, including the glovebox lamp and courtesy lamp type. Also a reformat for an easier read. Hope it helps!
Cheers,
Users browsing this forum: No registered users and 35 guests
