Club323F • View topic - Enlighten me.
It is currently Wed Nov 11, 2026 10:48 am
IanF
 Post subject: Enlighten me.
PostPosted: Fri Sep 24, 2004 11:50 am
I've just noticed that my drivers side headlight is smashed, not sure how or when it happened, there's no signs of any other damage around there, so looks like I need a replacement. I've seen the SEL-Imperial link from searching on this forum, so will probably order one from there. What I don't know is whether I need an electric one or a manual one as the SEL-Imperial site has both.
If it helps, it's for a 1998, 323zxi 2ltr V6 Special Edition and on the dash there's a roll wheel that I can adjust the level of the lights with.
Cheers,
IanF
IanF
PostPosted: Fri Sep 24, 2004 12:09 pm
Erk!!! Just phoned up Mazda to see what price theirs are and nearly died when I was told £199.52 come to think of it he didn't say if that included VAT, and it definatly didn't include fitting!!!!
Yeeps....
PostPosted: Fri Sep 24, 2004 1:50 pm
Try Ebay or scrapyards.... I know ebay had some for sale for, dont quote me tho, about £30 a while back
Stealth
PostPosted: Fri Sep 24, 2004 1:57 pm
You want an electric one if you have a lil' wheel that lifts and dips the headlight beam at night.
IanF
PostPosted: Fri Sep 24, 2004 2:16 pm
Ta very much Stealth. I'll be placing an order with SEL-Imperial then... Ho hum, 75 quid-a-roonies I didn't want to have to spend, but at least it's not 200 quid-a-roonies that I REALLY didn't want to have to spend....
Anyone else used/recommend SEL-Imperial?
Also is it a doddle to fit the headlamp? I assume it just involves undoing several screws and detaching a power lead, then redoing them all with the new unit?? Do I have to worry about leveling the beams, or is that all taken care of by the thumb wheel jobbie?
Cheers,
IanF
PostPosted: Fri Sep 24, 2004 4:35 pm
Here ya go mate. Probably the cheapest option :)
[url]http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=52640&item=2491122362&rd=1[/url]
You will most likely have to adjust the headlights yourself but thats easy, just involves a bit of screwing. Look in the guides section.
IanF
PostPosted: Mon Sep 27, 2004 11:25 am
Cheers, but that's the wrong one.
Any opinions out there as to how easy/tricky it is to fit one? From having a nosey around in the engine bay it looks a bit of a nightmare of pipes making acessing the relevant screws/nuts/bolts a bit of a sod.
Cheers,
Ian
PostPosted: Mon Sep 27, 2004 3:24 pm
Theres 3 bolts holding the headlight in place ... thats it - unscrew em and pull the unit out, making sure you have disconnected the electrical bits on the back .. simple :P Reverse the above to put back in
IanF
PostPosted: Sat Oct 09, 2004 8:50 am
Well it's all sorted now :D :D . Rather than pay Mazda £200 + VAT, I found a website called www.carlamp.co.uk which supplied me a light within a week for £105 including vat and delivery. YAY!
As it was so much cheaper I was half expecting a Tescos Value type brand one, but no it's an original Bosch one which is the same type that's supplied with the car. So if you need a new light I'd recommend them based on my experience.
Obviously I'd rather have paid much less for a 2nd hand one but it appears 323fs are like rocking horse shite around East Anglia. I phoned LOADS of scrappys but none of them had one.
Ah well the cars back to looking perfect again now so all's well that ends well....
IanF
IanF
PostPosted: Sat Oct 09, 2004 10:36 am
Forgot to mention, Gogobroom was right it's a doddle to remove and replace the headlight. There's just 3 nuts holding it in place and 2 power leads to disconnect, then it slides out to the front. In fact you'd have to remove it to replace the bulbs.
Cheers,
IanF
Dragon Rob
PostPosted: Sat Oct 09, 2004 2:21 pm
You can change the bulbs without removing the unit but need dexterous fingerwork!
As for lack of f's in East Anglia, there are loads on the roads, I see at least 3 to 4 a day, problems is they are just so hard to kill there aren't many in the scrappies! (but thats why i luv em) :)
Full Circle:-
