It is currently Sat Sep 12, 2026 2:24 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
 Post subject: Re: BA Help buggered
PostPosted: Tue Aug 13, 2019 1:11 pm
Not trying to be funny or silly with the following, but
- have you double-checked the clutch pedal mechanism is actually still connected to the clutch master cylinder plunger/mechanism?
- otherwise there's a blockage in the pipe/reservoir and that should be easy to check. You didn't 'bung' or seal a pipe with a small plug and forget to remove the 'bung' when you reconnected the pipe?
They are the types of mistakes I make.
BRV-6
PostPosted: Wed Aug 14, 2019 8:00 pm
:lol:
Know what you mean :lol:
The plunger mechanism is attached though, I didn't block the end with a bung.
I used a brake pipe clamp to nip up the line to swap out the master just in case it was a dud.
Still have the same problem with the new master though, no movement in the level of the resevouir when bleeding :?
Going to replace the pipe with the fuel pipe i have, finger's crossed it works :oops:
PostPosted: Fri Aug 16, 2019 6:29 pm
Any luck so far?
Users browsing this forum: No registered users and 18 guests
