thought it would be about time to update this a little, after reading the last post, oh i wish that was all i needed.....lol
anyway, the test was actually on monday, not the fortnight before, and i failed, but not on the things i was worried about, mainly emissions, and a worn offside cv boot.
failed on....
brake imbalance across an axle
both front brake hoses worn
no retaining clips on any of the brake hoses
blown rear brake light
torn nearside cv boot
then advisory for
offside rear brake hose showing signs of wear
offside front cv boot cracked but not allowing dirt in
misting on the front nearside shock
oil leak
I didnt think it was that bad.....
so ive been busy, frustrated, relieved, frustrated, nervous and then over the moon in the space of two days.....
replaced both front brake hoses, the ones from ebay, company called keep_driving, dont fit, had to be modified, but now fit a treat,
the offside front caliper was sticking, so stripped it down, regreased the slider and is all good.
replaced the cv boots with e-z boot, very tricky indeeed, but easier than the alternative
fitted all the brake hose retaining clips, dont know why i didnt do this when i fitted the new suspension.
re-tested, and passed.....over the moon.
i bled the brakes as you do, but tester mentioned it was still a little soft, but not too sotf that it would fail the mot, but advised to re-bleed when i get home.
re-bled all the brakes when i got in, but when i got to offside rear, i was a bit too enthusiastic when tightening up the nipple and sheared it, thankfully when it was closed......
so after a bit of a panic and thinking the worst, stu said all i would need was a new brake cylinder, phew.....
so this morning ive picked up a couple of new cylinders, £30 for both from eurocarparts, happy with that price
a new set of brake shoes, may as well if im opening up the drums
and postie has just delivered the rear brake hoses
and then as some of you know, Womble is being sold
im upgrading to a v6
a very nice one, a very nice white one too....
But dont worry, Womble shall live on, she is going to a guy i know in my local car club, and he plans to turn her into a track car.......hence why im making sure she stops when needed......yes i know it would be the new owners responsibility to make sure the brakes are good before he gets her on track, but i can at least sleep on a night knowing that the brakes, at the very least are reliable......
