Club323F • View topic - BA - Maddy in banzai mag! XD
It is currently Tue Nov 03, 2026 7:44 am
[url=http://www.club323f.com/forum/viewtopic.php?f=14&t=34875]Explained in detail here[/url]
Post new topic Reply to topic  [ 525 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12 ... 18  Next
PostPosted: Tue Mar 13, 2012 12:23 pm
[quote="323F Rock"]What are you doing in way of belt tensionising?[/quote]
from what he has told me the bracket is going to be adjustable outwards so there is no need for a tensioner.
PostPosted: Tue Mar 13, 2012 12:49 pm
yes mate, i beleive there is some tensioning movement on the power steering pump, but i will slot the holes on the bracket making it adjustable if there isnt enough movement on the PS pump.
PostPosted: Tue Mar 13, 2012 2:07 pm
My Car: Mazda 323F GTR
[quote="Lerch"]if there isnt enough movement on the PS pump.[/quote]
with the right size belt there should be plenty of adjustment with just the power steering pump :D
bikingpro5
PostPosted: Tue Mar 13, 2012 3:37 pm
[quote="323F Rock"][quote="Lerch"]if there isnt enough movement on the PS pump.[/quote]
with the right size belt there should be plenty of adjustment with just the power steering pump :D[/quote]
mine is adjusted via the PS pump only.
PostPosted: Tue Mar 13, 2012 7:03 pm
[quote="bikingpro5"][quote="323F Rock"][quote="Lerch"]if there isnt enough movement on the PS pump.[/quote]
mine is adjusted via the PS pump only.[/quote]
have you mounted yours directly to the block dude or via a plate? i found 2 unused boses on the block and drilled and tapped them to mount a plate to and then the SC, its seems plenty strong enough at the moment but the really test will be when its belted up and turned over.
bikingpro5
PostPosted: Tue Mar 13, 2012 7:11 pm
[quote="Lerch"]
have you mounted yours directly to the block dude or via a plate? i found 2 unused boses on the block and drilled and tapped them to mount a plate to and then the SC, its seems plenty strong enough at the moment but the really test will be when its belted up and turned over.[/quote]
mine is mounted to a plate that uses 4 OEM bolts to hold the plate, then 4 more bolts to lineup the SC properly for the belt
[img]http://i1100.photobucket.com/albums/g414/Bikingpro5/Winter%202011/Winter%202011%20Mobile/IMG-20120216-00015.jpg[/img]
[img]http://i1100.photobucket.com/albums/g414/Bikingpro5/Winter%202011/Winter%202011%20Mobile/IMG-20120216-00016.jpg[/img]
PostPosted: Tue Mar 13, 2012 7:38 pm
looks similar to what im doing bud! very nice work there :D
the SC im using doesnt have a flat side to mount to the plate and the mounted extrusions dont protrude past the sides so im having to use extension peices to mount the SC to the plate. I thought it would increase the instability of it but we will soon find out :)
Lethagized
PostPosted: Tue Mar 13, 2012 9:29 pm
[quote="Lerch"]new roof spoiler!!! yeah boy :D
[url=http://imageshack.us/photo/my-images/856/20120310135202.jpg/][img]http://img856.imageshack.us/img856/5776/20120310135202.jpg[/img][/url][/quote]
I recognise that scrappy? ABC Tividale. Has he still got that green BA or has he got a red one in now being as you have a bonnet on your roof?
The SC fitment looks interesting. Will be interested to know how quick the car will be once up and running. Good luck with the build.
PostPosted: Tue Mar 13, 2012 9:30 pm
yeah lerch I want a dyno before and after to see full gains
ziggy323f
PostPosted: Wed Mar 14, 2012 12:38 am
[quote="Lethagized"][quote="Lerch"]new roof spoiler!!! yeah boy :D
.[/quote]
That guy is a LEGEND!!!!!! :D :D :D :D
PostPosted: Fri Mar 16, 2012 8:28 pm
right so time to make room for the SC and get rid of the AC pump.
[url=http://imageshack.us/photo/my-images/805/20120316152909.jpg/][img]http://img805.imageshack.us/img805/1641/20120316152909.jpg[/img][/url]
pump off leaving the mounting bracket which im now gonna modifiy my bracket to bolt on to
[url=http://imageshack.us/photo/my-images/854/20120316180835.jpg/][img]http://img854.imageshack.us/img854/4205/20120316180835.jpg[/img][/url]
[url=http://imageshack.us/photo/my-images/213/20120316181654.jpg/][img]http://img213.imageshack.us/img213/8185/20120316181654.jpg[/img][/url]
everything removed ready for work to begin tomoz :)
[url=http://imageshack.us/photo/my-images/62/20120316181725.jpg/][img]http://img62.imageshack.us/img62/1167/20120316181725.jpg[/img][/url]
bring on tommorrow :D
bikingpro5
PostPosted: Fri Mar 16, 2012 8:34 pm
looks like fun.. my bracket that holds the SC was made to bolt up where the AC compressor used to be and eliminates the OEM bracket.
PostPosted: Sat Mar 17, 2012 6:13 pm
i have been a busy bee today :D
[img]http://i981.photobucket.com/albums/ae293/lerch211/20120317_161813.jpg[/img]
[img]http://i981.photobucket.com/albums/ae293/lerch211/20120317_162156.jpg[/img]
[img]http://i981.photobucket.com/albums/ae293/lerch211/20120317_162146.jpg[/img]
[youtube]2lQ5xAITSFs[/youtube]
PostPosted: Sat Mar 17, 2012 8:18 pm
AMAZING........ just need it plumbed in now
Sloth
PostPosted: Sat Mar 17, 2012 9:42 pm
Nice :D
Now that you've removed the AC pump, that fan opposite the SC will never come on, so you can lose it for more room :)
errnee
PostPosted: Sat Mar 17, 2012 9:46 pm
Good work. 2 things missing. A vacuum Block and a breather tank :evil4:
PostPosted: Sun Mar 18, 2012 2:31 pm
taken everything back off today to re-design the plate, make it a bit stronger and use a better idea i should of thought of in the first place but hey ho!
need to look into the oiling side of things
PostPosted: Sun Mar 18, 2012 2:49 pm
oil side of the super charger. Basically they have their own special oil.
http://www.ebay.co.uk/itm/Eaton-Whipple ... 3449908914
_MoReNo88_
PostPosted: Mon Mar 19, 2012 6:50 am
Wow!!! Niiiicee... :D
PostPosted: Thu Mar 22, 2012 12:02 am
couple of quick pictures from today's work
new mounting plate, stronger with fully welded 30mm bosses :)
[url=http://imageshack.us/photo/my-images/138/20120320145055.jpg/][img]http://img138.imageshack.us/img138/5802/20120320145055.jpg[/img][/url]
charger after blasting and spraying bolted to the plate :)
[url=http://imageshack.us/photo/my-images/585/20120321224135.jpg/][img]http://img585.imageshack.us/img585/1286/20120321224135.jpg[/img][/url]
and a sneak peak inside :)
[url=http://imageshack.us/photo/my-images/818/20120321224112.jpg/][img]http://img818.imageshack.us/img818/3522/20120321224112.jpg[/img][/url]
PostPosted: Thu Mar 22, 2012 12:05 am
looking a lot safer with those bigger mounts
bikingpro5
PostPosted: Thu Mar 22, 2012 1:38 am
mounting plate looks much better
PostPosted: Sat Mar 24, 2012 10:06 pm
few pics from today
[url=http://imageshack.us/photo/my-images/703/20120324171017.jpg/][img]http://img703.imageshack.us/img703/6928/20120324171017.jpg[/img][/url]
[url=http://imageshack.us/photo/my-images/840/20120324171011.jpg/][img]http://img840.imageshack.us/img840/2959/20120324171011.jpg[/img][/url]
PostPosted: Wed Mar 28, 2012 8:45 pm
so with a new bonnet being sprayed anyway, i decided to use the roll of wrap i brought ages ago and tackle the bonnet with nathan and lee........ big thanks to both of you by the way :D
[url=http://imageshack.us/photo/my-images/3/20120328181947.jpg/][img]http://img3.imageshack.us/img3/9118/20120328181947.jpg[/img][/url]
[url=http://imageshack.us/photo/my-images/708/20120328182003.jpg/][img]http://img708.imageshack.us/img708/8928/20120328182003.jpg[/img][/url]
[url=http://imageshack.us/photo/my-images/215/20120328182405.jpg/][img]http://img215.imageshack.us/img215/9020/20120328182405.jpg[/img][/url]
[url=http://imageshack.us/photo/my-images/696/20120328195803.jpg/][img]http://img696.imageshack.us/img696/6851/20120328195803.jpg[/img][/url]
[url=http://imageshack.us/photo/my-images/715/20120328195132.jpg/][img]http://img715.imageshack.us/img715/649/20120328195132.jpg[/img][/url]
i like it :D
ChrisL323f
PostPosted: Wed Mar 28, 2012 10:24 pm
I like it too :thumbright:
PostPosted: Thu Mar 29, 2012 8:19 am
sweeeeeeet :D
get some daytime pics up now!
considering that was our first attempt at anything like that i think we all did really good :D
Debz
PostPosted: Thu Mar 29, 2012 8:32 am
Nice :thumbleft:
[img]http://i286.photobucket.com/albums/ll94/chuckles_039/V6/debbie-sig.jpg[/img]
[color=#4000BF]Don't ever tell a woman her place is in the kitchen. That's where the knives are. So, don't piss off the women, men...[/color]
DMS
PostPosted: Thu Mar 29, 2012 8:50 am
Excellent job 8) 8)
PostPosted: Thu Mar 29, 2012 9:00 am
Good skills chaps :)
PostPosted: Thu Mar 29, 2012 9:59 am
ill take her out tonight and take some sexy pics :D
