It is currently Sun Aug 09, 2026 3:53 pm
Post new topic Reply to topic  [ 158 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Sun May 23, 2010 8:30 pm
Neil F wrote:
YIKES! :lol:
Looks pretty daunting mate, good on ya! :thumbleft:
Cheers fella
It was actually suprisingly simple - the hardest part was access on the drivers side as there is about a foot between the car and the house :lol:
All the nuts and bolts are in labelled sealable bags - and i have pics to help with the reinstall :lol:
nicola-thomas
PostPosted: Mon May 24, 2010 3:35 pm
looking really good this.. keep up the good work
PostPosted: Wed Jul 28, 2010 3:50 pm
Thought i'd better update here with some pics as i've posted in the "what have you done" thread
So, am about a third of the way through routing this loom through the wings and cabin of the car.
Here is where i started, lined these connection blocks up with where they need to be
Then Cable tied the new loom to the existing loom in the arch
This is where it came into the car, i actually pulled a lot of the existing wiring through here so i could pass the new wiring through the Gromet (not a job i recommend to anyone :evil4:)
And here is the loom draped across the "dash" area. need to route it behind the heater unit and then start plugging it in
I Have another loom to put in behind the heater units at the same time - that one needs a little soldering behind the dash and then also goes with this loom through the gromet on the other side of the car into the drivers arch :roll:
Then with that done i think i can put all the dash back in and finally sort out that rust in the engine bay :evil4: and turn my attention to more "mechanical" things ;)
As i said before i put my new custom instrument loom onto the "top" of the dash in the house, i havent any photos of that at the mo, but i may get some and post them up if anyone is interested :dontknow:
tcyjohnny
PostPosted: Wed Jul 28, 2010 4:44 pm
That's one big milestone matt! well done!!!!
RHRH
PostPosted: Wed Jul 28, 2010 5:00 pm
Well done mate, your also tucking the loom away?
Hope everything works...
What was It you needed from the seats, Ive forgotten... sorry... :oops:
Also I need something from you again also, the explanation of the
letters from the .pdf you sent me some time ago from the FBA loom
connectors.
with the letters... remember?
Ive got issues with IDing a connector, tried to check with somebody elses 1.8 but he had post ford and Ive got pre... different connector. :?
Its a yellow one with 12 flat pins... proper data connector looking thing,
I believe its somewhere on the back end of the engine...?
But I couldnt find it at all... Im now 3 connectors away from splitting up the 1.8FBA loom for the engine bay electrics and then will use the GTX loom for the megasquirt stuff. :D
Let me know about the seat again and Ill sort it out! :D
PostPosted: Thu Jul 29, 2010 6:05 pm
TODAY
Passenger wheel arch liner back in, drivers side out
Once it was out i realised that i didnt need to run all of the wires in my new loom down the wing (not the one i was installing but the other one that went from behind the dash and down the drivers wing ;)) - so i took it back in the house and removed the excess wiring before starting to put it in :D
Tomorrow i get ready for my camping weekend and hopefully manage to unclip all the original loom driverside so i can push the grommet through, push all my wiring through it and clip it all back in place
Then next week will be some in car soldering :D and then i can put the whole dash back in :D and take some photos ;)
DMS
PostPosted: Sun Aug 01, 2010 11:56 pm
All credit to you Matt. I wouldnt have the guts to try something like this :thumbleft:
PostPosted: Sat Aug 07, 2010 8:38 pm
today i pulled out my heater units - passed my new wiring through the drivers side wing grommet and then started putting all the new looms into the loom bracketes behind the dash
Put the central heater bit back in - bolted in as it wont need to come out again
(hopefully) Tomorrow i'll clip the "stray" wires into the connection blocks they need and then look to solder in the 2 wires that need splicing into the main front loom
Once that is done the dash can go back in
No photos at the mo as not a lot looks different from the last ones (as i pulled everything our and then put it back in again :evil4:) - but i'll take some progress shots tomorrow as i start to put things back together :thumbright:
PostPosted: Sun Aug 08, 2010 1:56 pm
Ok, so here is the update
Wiring is all in place - all wires clipped in or soldered (not many soldered :thumbright:)
I pulled the heater out again, opened up the little bracket things and routed the wiring through them, plugged it all in where necessary.
The worst ones were the connectors that are under the heater unit, had to take all of that apart, and the door connectors, had to try and get the wires into the door connectors without being able to unplug the connectors :roll:
Anyways, dash, airbag, instrument cluster all back in
Slight problem, i've misplaced some of the trim screws so off to scrapyard in the week to sort them out :lol:
Next step is to wire in a sensor in the bumper and then i can turn my attention to under the bonnet for a bit
RHRH
PostPosted: Sun Aug 08, 2010 2:27 pm
Oooh I see something automatically cool in those pictures! :shock: :D
Hope all your plans work mate!! :D
PostPosted: Sun Aug 08, 2010 2:47 pm
Yep that is why i have the Custom instrument loom, and what one of the custom front looms is for :thumbright:
It is it's own circuit, uses a couple of sensors around the car and only needs a little soldering to fit it into a UK BA instrument loom (after removing the heater wiring) :thumbright:
In the boot and where the back seats are supposed to be is all the piping to go under the bonnet - will leave that till last, got the brake and clutch lines to look at next :?
And i still need to get a clutch :(
PostPosted: Sun Aug 08, 2010 4:49 pm
Nice work fella :)
PostPosted: Sun Aug 08, 2010 7:32 pm
marcrs wrote:
Nice work fella :)
Cheers fella - may have a refurb favour to ask of you if you're up for it
Would be a few sets of calipers though.......
PostPosted: Sun Aug 08, 2010 9:39 pm
Be pleased to help in any way I can mate :)
 Post subject: Re:
PostPosted: Wed Jan 05, 2011 10:25 pm
Well i've had to remove the wiper mech and the master cylinder to be used on my daily driver, so now that i've started on the brake stuff i think i'll keep working on it over the next couple of weeks :D
Murray
PostPosted: Wed Jan 05, 2011 10:44 pm
2007............. :shock:
PostPosted: Wed Jan 05, 2011 10:48 pm
You fitted those brakes yet?!?!? :evil4:
PostPosted: Wed Jan 05, 2011 10:52 pm
yeah i know - should have taken nowhere near this long :lol:
At least maylander is taking just as long and his was pretty much a straight drop in :evil4:
I've spent all my time helping the 4th member of hanson install his rear disc conversion to be able to do my own :evil4: ;)
PostPosted: Wed Jan 05, 2011 10:59 pm
Touché.
:lol:
PostPosted: Thu Jan 06, 2011 12:00 am
I did not knew you could sing Hughie :lol:
'95: 323F BA 2.5 V6 J-spec @ 290 pk/ 322 nm
PostPosted: Thu Jan 06, 2011 12:05 am
:lol: I'm a man of many talents :lol:
PostPosted: Thu Jan 06, 2011 12:18 am
Can any of Hanson sing??? :evil4:
Simondo
PostPosted: Thu Jan 06, 2011 10:26 am
Nice work, Matt. :notworthy:
You're welcome.
PostPosted: Fri Mar 04, 2011 11:07 pm
today i put a new master cylinder and vac assist on the car today
Hopefully replace the brake and clutch lines soon and get some machining done to finish off me brakes :D
col
PostPosted: Fri Mar 04, 2011 11:17 pm
coming along nicely matt
ITS JUST NOT CRICKET
Dragon Rob
PostPosted: Sat Mar 05, 2011 11:41 am
Might be ready for JAE?? 2020 that is? :badgrin: :thumbleft:
Full Circle:-
PostPosted: Sat Mar 05, 2011 12:34 pm
Tell me about it, i went from having loads of time and no money to having some money and no time......
I gotta get it done soon though........
Touring Car Daz
PostPosted: Tue May 10, 2011 1:10 pm
Whats taking so long Matt???? :lol:
Daz.
cosmos1989
PostPosted: Tue May 10, 2011 1:30 pm
I remember joining being really excited about this one, take a 2 week holiday and spending 27 hours a day working on it ;)
"Meh, it was inside a condom and he used lots of lube, so it's fine" - Matty June 2011
Shaggy
PostPosted: Thu May 19, 2011 12:33 pm
Whats going on with this Matt?
You know there is no award for "longest conversion" :lol:
*******R.I.P - The Mystery Machine BA TURBO *******
