GTR
The Mazda 323 4WD GT-R is powered by an evolution version of the turbocharged and intercooled, type BPD, twin-overhead-camshaft, 16-valve, 1.839 cc, inline 4-cylinder engine. This power plant has been specifically developed for the GT-R by Mazda's Motor Sports Engineering Group. The type BPD "Big Turbo" produces 136 kW EEC (139 kW DIN) at 5,000 rpm and a maximum torque of 235 Nm EEC (240 Nm DIN) at 4,500 rpm, figures which are 13 and 8 % higher, respectively, than the output of the type BPD Turbo that powers the 323 4WD GT-X. The engine's strengths, both power output and torque characteristics, are in the mid-through-high-rpm zone, above 3,000 rpm up to its maximum allowable 6,500 revs. Numerous improvements have been carried out in the engine's internals, and the new "Big Turbo" and larger and more direct intercooler system is adopted in the GT-R unit.
The evolution version of the Type BPD, DOCH, 16-valve, EGI/Turbocharged Engine.
The type BPD DOCH engine has an 83.0 mm bore and an 85.0 mm stroke for a total capacity of 1,839 cc. The compression is 8.2:1 and the engine requires premium unleaded fuel (minimum RON 95). The cylinder head is precision diecast aluminum, carrying twin overhead camshafts. The single-stage, cogged-belt-driven camshafts operate 4 valves per cylinder via inverted bucket tappets that incorporate hydraulic lash adjusters, which maintain precise clearance without periodic adjustment. The camshafts are hollow-cast to reduce weight, each camshaft being 500 grams lighter than a comparable solid camshaft. The valves are Vee-inclined at an included single of 50 degrees in a compact pentroof combustion chamber with squish area. The spark plug is centrally located in the combustion chamber. Valve diameters are 33 mm (intake) and 28 mm (exhaust) having 8.0 mm and 8.5 mm lifts, respectively. The exhaust valves are sodium cooled. Encased within each thin, hollow, 6 mm valve stem is metallic sodium, which, when exposed to heat, liquefies and helps dissipate heat from the head of the valve.
Further, the piston's top ring groove area is reinforced with integrally cast nickel-based "metal foam". the nickel foam is produced by electroplating urethane foam, which is then melted away, leaving porous metal "foam". The foam ring is integrally cast in the piston by the squeeze-casting method. The metal reinforced, squeeze-cast piston with cooling channel was first adopted in Mazda's direct-injection diesel engine, whose piston are subjected to extremely high thermal load during the combustion process. The metal reinforced piston is about 10 % lighter as compared with an aluminum piston with Niresist top ring groove, and according to Mazda's testing has an extended piston life by threefold. The piston's skirt is also zinc-plated for improved wear resistance, and its inside is cooled by an oil jet. The forged steel connecting rods have a larger section for added strength. The connecting rod's big-end bearing is now of a racing-type kelment metal. The cast iron cylinder block's lower opening is reinforced by a Main Bearing Support Plate (MBSP), an intercately shaped steel plate which has dual functions: stiffening the block and effectively reducing vibrations, and securely supporting the lower cranshaft bearing caps. The oil sump is made of rigid, sound-damping diecast aluminum. Its front end is bolted onto the transaxle casting, contributing to overall power unit rigidity.
Fuel injection is by the latest digital-electronically managed, L-jetronic, multi-port injection system, with a flap-type airflow metering device. Fuel is injected to two cylinders simultaneously (cylinder 1 and 3 in one group and 2 and 4 in the other), in sequence. The lubrication system employs a high-pressure pump, and a water-cooled oil-cooler is integral with the filter. Ignition is electronically controlled with the engine control unit (ECU) determining option ignition timing by signals collected from the distributor, throttle sensor, airflow meter, coolant temperature sensor and knock sensor
TURBOCHARGER AND INTERCOOLER
The turbocharger was specifically developed for the GT-R application by IHI. The RHF6CB turbocharger has a 62.0-mm diameter turbine and a large 65.0-mm compressor. By comparison the turbo for the type BPD 1.8 liter engine that powers the GT-R has a 52.5-mm diameter turbine and a 52.5-mm compressor. It is commonly believed that a big turbo is employed for high rpm power. The Mazda and IHI teams have proven with the GT-R turbo installation that this is not necessarily so. They have sought and achieved an optimum balance between high power and quick mid-to-high rpm response. A relatively small "A/R" ration, a value of 16 to the GT-x's 15, was one of the means they adopted to assure these desirable characteristics. "A" is the smallest scroll area and "R" the distance between the turbine-shaft center and the center of area "A", the two factors used in calculating turbocharger's performance characteristics. The turbocharger employ's a steel turbine wheel for its proven reliability under the rigors of competition. In Mazda's testing it suffered little in responsiveness when compared with a unit fitted with an experimental ceramic turbine; the latter may be decelerating too quickly for any appreciable difference in pickup that follows. The turbocharger shaft is supported by ball bearing, which improves turbo response by as much as 7% by Mazda's testing.
The turbocharger is watercooled. Boost is controlled by a dedicated computer map, and its maximum pressure is 450 mm of mercury (Hg). The standard air-to-air intercooler is about twice the size of the unit fitted in the GT-X (235-mm wide, 225-mm high and 65-mm deep), and has a heat dissipating capacity of 6,150 Kcal/hour which is 36% more than the GT-X's. It features efficient "zig-zag" fins which increase cooling surface area. The intercooler is located in the nose of the car, immediately ahead the coolant radiator. the path the boosted air takes to the engine's intake system is as direct and short as possible, so that pressure loss is minimized.
Manifold System
With the "Big Turbo", it has become critical that boosted air is distributed to the individual cylinders in equal volume and pressure. Likewise, the energy of exhaust gas must be fully exploited to quickly "spin-up" the big turbine in order to obtain high power and minimum turbo lag.
The Mazda engine design team has perfected a unique manifold system, combining the air volume and pressure equalizing intake and exhaust extractor manifolds.
It was Mazda's finding that with more a more commonly used equal-length intake manifold, the tract nearest to the air entry received the least volume/pressure, and the farthest tract the most. By trial, measurement and testing, the engine team perfected a cast aluminum manifold that has intricately curved and sized "walls" between the individual tracts leading to the intake ports to equalize air volume and pressure. A bonus is that the manifold's swirl generating effect contribute to efficient combustion. The equalizer intake manifolds have shown its effectiveness in improving torque from idling to the Group-A 300-bhp-plus output level and all the way up to maximum revs.
The exhaust manifold has individual tracts collecting at the turbocharger entry. These tracts are in two groups; the tracts from cylinders 1 and 4 are routed to the center, and those from cylinders 2 and 3 to the outside. This routing allows nearly equal tract length. The complex manifold is made of cast ferrite steel, for which the lost-form casting method is employed. Not only is this about 20 percent lighter, much stronger and its passages much smoother than a conventional cast iron one, but also its surface finish is much smoother.
The exhaust manifold's extracting ability precludes an unwanted rise in exhaust back-pressure, which would cause the dilution of the combustion chambers with exhaust gas. This would, in turn, raise cylinder temperatures. Enriching the fuel/air mixture to lower combustion temperatures would obviously deteriorate fuel economy.
The GT-R exhaust system adopts a 3-way catalytic converter with larger capacity but a reduced number of cells, and a new main silencer that assures reduced resistance to gas flow.
[img]http://i8.photobucket.com/albums/a7/benjimort/gtr-19.jpg[/img]
