Club323F • View topic - TCS, ABS & Handbrake lights on ?
It is currently Tue Nov 17, 2026 9:24 pm
jmdrake
PostPosted: Sun Apr 18, 2010 11:40 pm
Hey Guys - I have had a problem recently ( another one I know) where the ABS, TSC & Handbrake lights are constantly on - Not every time but about 90% of the time - Is this a commonly known fault - I have plugged into diagnostic and no fault codes via Elm327 - have read the portage manual and there is a manual way of checking abs faults - will give this a go tomorrow - Before go through this anyone got any ideas?
errnee
PostPosted: Mon Apr 19, 2010 9:05 am
ABS wheel sensor? But its finding which one :scratch:
PostPosted: Mon Apr 19, 2010 12:54 pm
rear passenger one seems to be the favourite.
tcyjohnny
PostPosted: Mon Apr 19, 2010 1:49 pm
I had these after a little funny skidded braking to a stop (on a sunny dry day) once:
[img]http://i76.photobucket.com/albums/j26/tcyjohnny/bjsport/DSC00054.jpg[/img]
Got home with these on, folded the back seats forward, taken out the trims either side, then unplugged the connectors, wipe them with my already greasy fingers, put them back, and it was gone. But not sure if you have the same problem as i my handbrake light wasn't on all the time?
Just a thought, it was also before I got my rear sticky caliper fixed, so maybe it's someting to do with that too? have you checked?
jmdrake
PostPosted: Sat Apr 24, 2010 9:43 pm
Neil - Funny enough - thats the faulty one - I checked the tolerances on all the sensors and as you said the rear Passenger one is out of range - After checking and putting all back together - the lights were fine for 2 days but they came back on today - Next question is -these seem to be Very expensive - I have been quoted £70 for the one rear sensor - I have tried breakers yards but no luck - I have seem OEM ones on ebay for £50 - Anyone know if they are available any cheaper from anywhere else ????
cristiflorea
PostPosted: Sun Apr 25, 2010 9:04 am
Hello, I have the same problem and I ... ABS and brake light bulb turned on. codes say I left rear sensor blocked. I changed but show the same problem. you have other ideas?
bumperb
PostPosted: Sun May 02, 2010 3:35 pm
I have the same problem, had garage to a flash test on the diagnostics, they got 2 error codes. one says wiring problem & other says n/s/r abs sensor.
Going to do a wiring check later in week & if it's not that looks like a sensor n/s/r from the diagnostics.
Mazda 323f BJ 2001 1840cc.
Any one got any suppliers they can recommend rather than Mazda Spares?
jmdrake
PostPosted: Sun May 02, 2010 5:52 pm
Right guys - Fixed the fault - I bought a new Rear ABS sensor from ebay for £49.99 ( the cheapest I could find) I had quotes ranging from £70+vat for new to £108 for second hand sensor !!!!- changed the sensor cleaning out the hole it goes into with a dremel and checked the gap and all working fine - no more lights on.
The removal of the old sensor is difficult - many years or rust had really got it stuck - Using a very small screwdriver i managed to get it behind the bolt fixing and using 2 larger screwdrivers - prised it out slowely - while i was there I checked the rear brakes and dismantled and cleaned all the handbrake connections greasing all the contact points for easy removal in the future. - good job done..
PostPosted: Wed May 05, 2010 11:23 pm
Nice one mate, glad its sorted. :D
Zeek
PostPosted: Sun May 23, 2010 2:45 pm
Hi guys, I have the same problem myself... TCS/ABS & handbrake warning light stays on most of the time........... BUT..... this has only just started happening a couple of days since I had 2 new tyres put on the front & the tracking done............... is it possible that summat was touched during this process, or just coincidence that it has happened now & is more likely to be the rear??................ I am a newbie to this forum, are there any links on here to solving this problem with pics & or data to set up the gap/s ............ cheers guys for any help you can give.... :)
PostPosted: Sun May 23, 2010 7:25 pm
Hi Zeek, welcome in. :D
I don't think you need to set the gap, the sensor just bolts in place.
Its likely coincedence, but obviously there is the chance something was done too, made a tugged or snagged wire? :dontknow:
Have a look at the wire and see if theres any visible damage. The wires go to the back of each hub. :wink:
Zeek
PostPosted: Sun May 23, 2010 7:44 pm
[quote="Neil F"]Hi Zeek, welcome in. :D
Have a look at the wire and see if theres any visible damage. The wires go to the back of each hub. :wink:[/quote]
Hi Neil, I did pop me head in the newbies 1st mate.......... ;) .... yea I will ave a look tomoz at that, It does come n go, but is ON more often than off.... & just so happens the MOT is due early in June....sods law aint it!!!,,,,,, :lol: ........... Cheers for the info though.......... 8)
