It is currently Tue Apr 24, 2018 9:18 am
Post new topic Reply to topic  [ 20 posts ]
JB
 Post subject: Cambelt
PostPosted: Tue May 26, 2009 3:43 pm
I got a 323F BG 1.8 -92
If my cambelt breaks, will my engine die?
Seems like its pretty hard to replace it (not much room) and i dunno if any previous owner have changed it, so i dunno if i should change it or not
cyberpaddy66
PostPosted: Tue May 26, 2009 3:49 pm
What mileage you done?
They should be changes every 65K miles so if your close it's not worth taking the risk to be honest.
JB
PostPosted: Tue May 26, 2009 4:02 pm
15 500 mil, that should be 96 312 miles, so i guess some of the previous owners should have changed it at least one time (i hope).
Is it easy to replace or do i have to lift the whole engine up to get enough room to replace it?
cyberpaddy66
PostPosted: Tue May 26, 2009 5:10 pm
It's fiddly but quite do-able, not sure if someone's done a guide yet but many have changed the belts on the road-side without much difficulty.
karissabob
PostPosted: Tue May 26, 2009 5:36 pm
The engine is safe if the cambelt breaks (happened to mine). Never seen the cambelt changing process though, the garage put a new one on, but then it did happen while it was in the garage.
Best to change it though, just to be safe :)
ladybird
PostPosted: Wed May 27, 2009 9:33 am
what sort of price would it be for a garage to fit new one???
" THE BUG " BG GT
" LEON CUPRA "
karissabob
PostPosted: Wed May 27, 2009 12:51 pm
Can't remember what mine cost, but it is the 1.6, and the cost was lost amongst all the other work that was done :roll:
gaznoiz
PostPosted: Wed May 27, 2009 2:03 pm
im changing the belt on the familia at some point it is a 1.6 dohc so similar to the 1.8 dohc you are on about , ill post a write up but it wont be for a fair few weeks yet. i change cambelts before 60,000 mile mark , also good to visually inspect the belts from time to time , as cars that are old or have been stood for a while might need a cambelt sooner .
ladybird
PostPosted: Wed May 27, 2009 3:00 pm
i think i got quoted bout £150 but that was with the old mechanic that i dont use or trust anymore. im sure mines overdue a change, luckily im not doing hardly any mileage in it at mo, and with still no bloody job it'll have to wait a few months more. :tard: :flower:
" THE BUG " BG GT
" LEON CUPRA "
PostPosted: Wed May 27, 2009 7:09 pm
I suspect you actually have the 1.8 SOHC, rather than the DOHC?
We didn't get the 1.8 SOHC over here, just the 1.6.
Both engines are safe if the cambelt snaps. :wink:
JB
PostPosted: Wed May 27, 2009 10:28 pm
I have the 1.8 DOHC, nice to hear that the engine is safe, but i might consider replacing the cambelt anyway unless i find some info somewhere when it was replaced last time
Danny-6000xtr
PostPosted: Wed May 27, 2009 11:02 pm
best to change it tbh. its about 5 - 10% cost to replace the belt as if the belt snapped. it cost 85% money to rebuild the engine
karissabob
PostPosted: Thu May 28, 2009 8:45 am
As Neil and I said, the engine is safe if the belt breaks. You just need to sort the timings out again, and buy a new belt, and fit it :scratch:
PostPosted: Thu May 28, 2009 10:20 pm
And of course, you need to get home using some other means of transport! :lol:
cyberpaddy66
PostPosted: Fri May 29, 2009 9:59 pm
PHEW!
I was a bit worried about that myself, thanks Neil :D
mazz
PostPosted: Fri May 29, 2009 10:04 pm
well i csn deffo vouch that they be fine...
after mine had a fit and broke, lol
its a pig or can be if the lower bolt gets stuck.. :lol:
but dead easy to change yourself otherwise :)
Club 323 swindon division :)
Fleet of 8 & still going strong 8)
Nes, Ghost, White shite 1, White shite 2, Messiah, Kgb, Bug & Riot
www.reefgeeks.co.uk
bullit
PostPosted: Tue Jul 14, 2009 8:26 pm
i heard knicker elastic works
wudnt know as dont wear em
ladybird
PostPosted: Wed Jul 15, 2009 6:44 pm
R U sure ??? :badgrin:
" THE BUG " BG GT
" LEON CUPRA "
cyberpaddy66
PostPosted: Thu Jun 17, 2010 5:47 pm
Does anyone have a good EASY way of undoing the bottom pullet cam belt flange bolt?
Asked a few garages and most of them said 'Air Gun' but seeing as I don't have access to one of them I might have to go with what one garage said and that was to use a 'strong arm' wrench and a good socket, un-clip the HT lead and give the engine a quick flick with the starter motor. I don't know about you but this sounds very dangerous!!!
I need to get this dam belt changed before the weekend as I was planning on going to my parents (3.5 hour drive) and I don't want to risk the current belt as the car has now done over 120K miles and I have no way of telling if the previous 6 owners did the timing belt change ar 65K miles (gulp).
PostPosted: Thu Jun 17, 2010 6:22 pm
sounds about right to me with the big bar etc, as long as you take note which way the engine spins then put bar on in the correct way.
Users browsing this forum: No registered users and 0 guests
