Club323F • View topic - Gearboxes - what will fit ?
It is currently Sun Oct 25, 2026 7:07 am
PostPosted: Tue May 17, 2011 10:52 pm
[b]Gearboxes[/b]
With so many people asking questions about them (final drive ratios etc) I thought it would be appropriate to pop it all down in writing on our forum in one place :)
[b]Car / Engine[/b] MX-3 (K8) & Probe GT (KLDE) [b]Gearbox[/b] G5M-R
Gear Ratios (Input:Output)
1st 3.307:1
2nd 1.833:1
3rd 1.310:1
4th 1.030:1
5th 0.795:1
Final Drive [b]4.388:1[/b]
[b]Car / Engine[/b] MX-6 KL-DE & 626 KL-DE [b]Gearbox[/b] G5M-R
1st 3.307:1
2nd 1.833:1
3rd 1.310:1
4th 1.030:1
5th 0.795:1
Final Drive [b]4.105:1[/b]
These two gearboxes are identical except for the final drive ratio which I have highlighted, this difference should equate to around 250 - 300 rpm in the real world
[b]Car / Engine[/b] MX-6 FS-DE & 626 FS-DE [b]Gearbox[/b]G25M-R
1st 3.307:1
2nd 1.833:1
3rd [b]1.233:1[/b]
4th [b]0.914:1[/b]
5th [b]0.717:1[/b]
Final Drive 4.105:1
In this gearbox you can see that 1st, 2nd and Final drive are all the same as the other boxes, the difference is in 3rd, 4th and 5th. I'm not able to work the difference in rpm by using the 5th gear in the MX-6 V6 gearbox but I would have a good guess that it would be a little lower still.
The G15M-R gearbox is used in the BJ Diesel (RF-MDT) I'm sure as the other gearboxes are interchangeable then it would physically fit onto the V6 but I can't be sure, it does however benefit from a lower final drive ratio so for those of us that want a lower cruising rpm then it would be perfect to swap over the final drive ratios.
I'm pretty sure this will all apply to the BJ sport too as some of the gearboxes are the same :)
More info will be added pretty soon but bed is calling :roll:
The info in this thread is what I have collected over the past year so may not be 100% upto date. Some things may not fit and as I haven't tried everything personally I won't be held responsible for people buying stuff then finding it won't fit :lol:
Stu
marshymob
PostPosted: Tue May 17, 2011 11:03 pm
My Car: Julie - 1994 BA
sorted, and thanks again 8)
PostPosted: Tue Oct 25, 2011 8:48 am
Hmmm, are there any gearboxs with a better 2nd gear I wonder, I hate 2nd in the 1.5, way too tall :?
PostPosted: Tue Oct 25, 2011 1:39 pm
5th needs to be much longer i think! feel likes im raggin the hell out if doing 85/90
marshymob
PostPosted: Tue Oct 25, 2011 8:04 pm
on track or private road of course lee :D
PostPosted: Wed Oct 26, 2011 4:20 pm
[quote="marshymob"]on track or private road of course lee :D[/quote]
old airfeild runways matey
PostPosted: Wed Oct 26, 2011 5:16 pm
What? Longer? You're joking right? 5th gear in post BG cars is an economy cruise gear, whereas, 5th gear in the BG GT is a proper gear you can even use to overtake wuth :thumbright:
Still hate 2nd :banghead:
PostPosted: Thu Oct 27, 2011 7:53 pm
I hate 5th, it's not economy :lol:
I'm not sure there is a different second without having it swapped out for a different one. . .:(
PostPosted: Fri Oct 28, 2011 9:01 am
Its to do with reduced emissions and such like chap, most manufacturers ruined their gearboxs by fitting longer top gears in the mid nineties! :)
PostPosted: Fri Oct 28, 2011 6:30 pm
I really wish the V6 had a longer 5th, it's for too short :(
PostPosted: Fri Oct 28, 2011 8:44 pm
Swap ya :D
Kragus27
PostPosted: Tue Nov 22, 2011 6:09 pm
ok so if the box in my 1.5 BA goes what would my options be? Thanks
RHRH
PostPosted: Wed Jan 11, 2012 4:39 pm
[quote="andym323"]What? Longer? You're joking right? 5th gear in post BG cars is an economy cruise gear, whereas, 5th gear in the BG GT is a proper gear you can even use to overtake wuth :thumbright:
Still hate 2nd :banghead:[/quote]
I love the 2nd on the Fseries box in our cars!! It's better suited to the 1.8 engine though...
I've got some interesting information to add here maybee... It's more suited to boost applications but still...
Mazda has done some design work over the years...
Look at the diagonal part between the section of the box holding the gears and the diff... The triangel shape...
Then scroll down!
[img]http://i226.photobucket.com/albums/dd300/Koivusalo/AWD/plaincasing.jpg[/img]
G5M
[img]http://archive.pixbox.se/arkivet/synligt_35/29290000-29299999/640x480w/29297451.jpg[/img]
G25M (upgraded Gserie)
[img]http://i227.photobucket.com/albums/dd200/jesiotrot/gearbox/S1030398.jpg[/img]
H series
[img]http://i302.photobucket.com/albums/nn104/Jaakkoseta/HPIM4427.jpg[/img]
Welded up
THIS is the part where all mazda boxes go to shit when boosting!! Just wanted to add this, I understand
this is not about boosting but still... It seems the box actually flexes at the part between the diff and
part where the gears are...
Found this by accident on a US forum... :shock:
PostPosted: Thu Jan 12, 2012 1:33 am
Very Very interesting, I'm seriously going to have to look at this :)
PostPosted: Fri Jan 13, 2012 2:01 am
Those vents on the bottom of the box in the third picture, not seen them before :scratch:
PostPosted: Fri Jan 13, 2012 6:41 pm
My Car: Mazda 323F GTR
it's a H series gearbox andy so probably not from a BA :)
PostPosted: Sat Jan 14, 2012 3:57 pm
Dammit, must look closer :p
