Club323F • View topic - Electrical Power dip when using electric windows..
It is currently Sun Nov 15, 2026 6:05 am
Sweedie
PostPosted: Fri Jan 13, 2006 5:36 pm
Does anyone know why the electrical power would dip when I use the electric windows, or if the ABS breaks hit?
One easy way to see is to stand with your carlights against a wall and then try to raise the windows. The lights will go dimmer as long as you hold the button.
The very same thing happen if you drive and then do a hard break so the ABS/Anti-lock system kick in. Then the lights dim and flicker - but also the car stereo cracks and blinks as it gets to little power.
The car has a new battery (early October 2005), and the car itself has only done 80000 km (49 700 miles). It is a 323F BA 1996 from Sweden.
Is it normal, common, or a "very bad thing™ "?
richardesty
PostPosted: Fri Jan 13, 2006 5:38 pm
Sounds like something is drawing more current than the battery could cope with......
My Subs and Amps used to make my lights dim to the time of the music - but a powercap put rest to that.
I'd check get your battery and altenator checked out....
fil_auto
PostPosted: Fri Jan 13, 2006 5:50 pm
[quote="richardesty"]Sounds like something is drawing more current than the battery could cope with......
I'd check get your battery and altenator checked out....[/quote]
... I may have to look into this too as I've noticed the lights dim a little when using the leccy windows!!! :dontknow:
Sweedie
PostPosted: Fri Jan 13, 2006 6:00 pm
I do not think it would be the alternator. The battery should cope with all the sudden current boosts needed. So I think perhaps badly charged battery or bad connections? I am just worried there would be some serious power problem somewhere, especially seeing the how much the powerdrain was with the ABS...
richardesty
PostPosted: Fri Jan 13, 2006 6:18 pm
Hmmm - could be a poor earth on the battery....
stuartspel
PostPosted: Fri Jan 13, 2006 6:31 pm
I reckon ALL F's will do this. I remember a thread a few months ago mentioning the same thing.
I urge all you with filament bulbs to try this. start your car, turn on headlights, try and close an already closed window whilst watching your lights.......
Bet they go dim.......!
PostPosted: Fri Jan 13, 2006 6:41 pm
Its a trait of most cars :P
m0053
PostPosted: Fri Jan 13, 2006 7:11 pm
see this thread: -
http://www.club323f.com/club323f/forum/ ... =capacitor
richardesty
PostPosted: Fri Jan 13, 2006 7:29 pm
[quote="stuartspel"]I reckon ALL F's will do this. I remember a thread a few months ago mentioning the same thing.
Bet they go dim.......![/quote]
There's your answer :cheers: Fit a Xenon HID convension kit and you won't have filament bulbs to go dim :thumbleft:
Sweedie
PostPosted: Mon Jan 16, 2006 10:45 pm
[quote="richardesty"][quote="stuartspel"]I reckon ALL F's will do this. I remember a thread a few months ago mentioning the same thing.
There's your answer :cheers: Fit a Xenon HID convension kit and you won't have filament bulbs to go dim :thumbleft:[/quote]Problem is still there with the Xenon lights, just not visible.
My biggest concern would be that power would drop to low when there is a panic break and I would loose control over the car etc...
m0053
PostPosted: Mon Jan 16, 2006 10:54 pm
i once took mine to the mazda garage for them to look at this and they said its normal
Sweedie
PostPosted: Mon Jan 16, 2006 10:55 pm
[quote="m0053"]i once took mine to the mazda garage for them to look at this and they said its normal[/quote]Hmm.. I still do not feel safe with it = (
shadowake
PostPosted: Mon Jan 16, 2006 11:19 pm
Mine does it pretty sure they all do, my partners ford KA does too, although that sounds like its going to cut out :drunken:
m0053
PostPosted: Tue Jan 17, 2006 12:58 am
the 'f wont cut out. i've tried!
if you turn your lights on, wait for the idle to settle at normal and then wack your heater up to full, change the heater mode (from demister to whatever) try to wind up both windows while they're already up, turn on the radio and press the brake pedal, it doesnt stall. the revs will just drop to 500rpm, the lights will dim but then it will right itself
shadowake
PostPosted: Tue Jan 17, 2006 9:35 am
[quote="m0053"]the 'f wont cut out. i've tried!
if you turn your lights on, wait for the idle to settle at normal and then wack your heater up to full, change the heater mode (from demister to whatever) try to wind up both windows while they're already up, turn on the radio and press the brake pedal, it doesnt stall. the revs will just drop to 500rpm, the lights will dim but then it will right itself[/quote]
You must have been bored ;) (although I must admit ive tried it myself :roll: )
Sweedie
PostPosted: Tue Jan 17, 2006 3:09 pm
if you turn your lights on, wait for the idle to settle at normal and then wack your heater up to full, change the heater mode (from demister to whatever) try to wind up both windows while they're already up, turn on the radio and press the brake pedal, it doesnt stall. the revs will just drop to 500rpm, the lights will dim but then it will right itself[/quote]Continous usage is not the same as spiking usage of current/voltage. In other words it doesn't mean so much if you can run all appliancies and thingis at once.
m0053
PostPosted: Tue Jan 17, 2006 6:35 pm
[quote="Sweedie"][quote="m0053"]the 'f wont cut out. i've tried!
if you turn your lights on, wait for the idle to settle at normal and then wack your heater up to full, change the heater mode (from demister to whatever) try to wind up both windows while they're already up, turn on the radio and press the brake pedal, it doesnt stall. the revs will just drop to 500rpm, the lights will dim but then it will right itself[/quote]Continous usage is not the same as spiking usage of current/voltage. In other words it doesn't mean so much if you can run all appliancies and thingis at once.[/quote]
i no, but if you try and turn them all on at the same time, as in pressing all the buttons in as short a time as possible, you are causing a spike
