Club323F • View topic - gearbox ratios - mod
It is currently Fri Nov 13, 2026 5:07 am
elesar
 Post subject: gearbox ratios - mod
PostPosted: Tue Dec 13, 2005 7:41 am
Hi all
I read a couple of things about the BA gearboxes setup. Maybe some of you can confirm/deny/comment on the following :
1. The gear ratio's are very long, which is a waste, as the engine can handle a shorter gear ratio. Apparently the later models had a new gearbox ratio which improved acceleration.
2. Has anyone here shortened/improved the ratio ? Would you have to change anything else on the engine/clutch to accomodate this change ?
Have a good one..
elesar
PostPosted: Tue Dec 13, 2005 9:07 am
I forgot to add....
Aparently if you change the final gear ratio, it will change all the other gears as well ... confirm ?
Shaggy
PostPosted: Tue Dec 13, 2005 11:20 am
Im not too sure about this but I read the earlier G series gearboxes had a shorter ratio and are better for acceleration :S
[url=http://www.cardomain.com/ride/2075708]*******R.I.P - The Mystery Machine BA TURBO *******[/url]
bioboost
 Post subject: gear ratios
PostPosted: Thu Dec 29, 2005 7:11 pm
my 323f is a m reg and the gear ratios are long i get 72 is 2sed gear how about that
elesar
PostPosted: Fri Dec 30, 2005 6:05 am
I haven't pushed it to 72 yet, but it's very close to that ... the problem is a short first and a very long second ... it should be a bit closer so that it "feels" the revs are being used.
bioboost
 Post subject: revs
PostPosted: Fri Dec 30, 2005 11:43 am
wot are you getting out of first if you give it some..i get about 40
elesar
PostPosted: Fri Dec 30, 2005 1:03 pm
I also get 40 ... which is ok I guess, but I also got that with my 1.3 Toyota , the top end in each gear is not the problem , it just takes a long time to get there, from 40 - 70 in second seems like forever .. some guys have shortened the ratio's so that the max is 60 in second, but they are much closer.
It's a big and expensive job to change the ratio's. I was just wondering if anyone feels that it is very long, or if it's just me :)
bioboost
 Post subject: i dont mind
PostPosted: Fri Dec 30, 2005 1:56 pm
i dont mind but the prob with my car is it dont go over 97
PostPosted: Fri Dec 30, 2005 3:41 pm
Something wrong there then, my 1.5 will easily reach 110mph and more, on private roads of course ;)
bioboost
 Post subject: min
PostPosted: Fri Dec 30, 2005 4:20 pm
i no but wot can one do
richardesty
PostPosted: Fri Dec 30, 2005 4:38 pm
Here's your gear ratios guys:
http://www.club323f.com/ba/articles/ba9 ... 8spec5.jpg
MRK189
PostPosted: Fri Dec 30, 2005 5:02 pm
to be honest even i feel that the gear ratios arent very good, 1st is very good but too short, 2nd is way tooo long and distant from 1st, 3rd and 4th i dont have a problem, 5th could even be longer.
richardesty
PostPosted: Fri Dec 30, 2005 5:08 pm
You all need 18's - that sorts the gearing out :cheers:
