Club323F • View topic - Central locking
It is currently Fri Nov 13, 2026 11:07 pm
matt4u
 Post subject: Central locking
PostPosted: Sun May 22, 2005 10:33 pm
are there known problems????
I have had no problems, all of a sudden it stopped working, the moters sound like they are jamming.
DuFFMaN
PostPosted: Sun May 22, 2005 10:41 pm
Is it attempting to work but not working?
Make sure your doors are closed.... If they are which they probably are... Make sure the little switch which is pressed when the door is closed is still working on all 4 doors.. If that doesn't work, the car thinks the door is open and wont lock it..
essex-lad
PostPosted: Sun May 22, 2005 10:45 pm
Yeah make sure all the doors are closed and the boot...... otherwise i've not heard of this problem before
matt4u
PostPosted: Sun May 22, 2005 10:52 pm
yea everything is closed, they make a noise like they atre trying to work but are locked
PostPosted: Sun May 22, 2005 11:09 pm
Try spraying the switches with a little switch cleaner spray, available from your local electronics outlet :D:D
matt4u
PostPosted: Sun May 22, 2005 11:18 pm
its not the switches though
essex-lad
PostPosted: Sun May 22, 2005 11:34 pm
:? now! not a common problem here. Is it remote locking or key?
matt4u
PostPosted: Sun May 22, 2005 11:55 pm
its running off my alarm, but if i press the button inside the car to unlock or lock the dors they dont work either, just make bad noises
essex-lad
PostPosted: Mon May 23, 2005 12:25 am
I think you are going to have to do some investigating mate. Maybe one of the door lock actuators is seized which would cause all not to work or maybe the contol box or relay (which i think is in the passenger footwell) is faulty
matt4u
PostPosted: Sun May 29, 2005 12:39 am
Well I had a play round and removed some plugs from the alarm main unit as it turns out th alarm is causing the problem.
essex-lad
PostPosted: Mon May 30, 2005 2:38 am
Well done mate
matt4u
PostPosted: Mon May 30, 2005 2:42 am
I'll know more thisafternoon as Im going down to the place that put it in,
matt4u
PostPosted: Mon May 30, 2005 7:20 pm
Well its all fixed, they just replaced the main control unit
